02-16-2023 05:24 AM
I have to update a Cisco CUCM from 12.5(1)su6 to 12.5(1)su7 to avoid a vulnerability.
I would like to ask if it's possible knowing the firmware of the IpPhones of the Cisco CUCM 12.5(1)su7 version.
I tried on Cisco site but I didn't find it.
Thanks in advance
Marco
Solved! Go to Solution.
02-16-2023 05:29 AM - edited 02-16-2023 05:33 AM
Here is a list of firmware, just scroll to the very bottom:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/sustaining/cucm_b_readme-1251su7.html
Hope that helps and good luck with your upgrade.
02-16-2023 05:31 AM
Cisco mentioned them on read me guides of the versions.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/sustaining/cucm_b_readme-1251su7a.html
02-16-2023 06:11 AM
Thank you Nithin
02-16-2023 06:11 AM
Thank you Ipersing
