hello Doan,
The "MediaListExhausted" notification means that the Cisco Unified Communications Manager has gone
through all of the devices in the Media Resource Group and was not able to assign a device to use.
This is more of a cosmetic notification and can be ignored unless you receive reports that outbound calls are
not completing. This RTMT notification is likely to appear when :
A number is not dialed correctly. You need to check with the end users to see if they have any
complaints.
a) Cisco Unified Communications Manager is integrated with the Private Branch Exchange (PBX) and a
user dials a number that does not exist on the PBX (an unallocated or unassigned number).
b) Complete these steps in order to stop these messages in the RTMT:
1. Choose Alert Menu > Set Alert Properties.
2. Choose the received alerts and uncheck Enable Alert or choose the alert type, for example,
MediaListExhausted.
3. Click Next
Configure a threshold in order to trigger the alert only when the number of MediaListExhausted
events exceeds a certain number within an hour. This reduces the number of alerts that are received.
Hope this helps!
Karthik
