Cisco CUCM configuration for same extension for ATA187 and existing Fertel IP phone
adeebtaqui
Level 4
Level 4
Is it possible to configure existing cisco CUCM for same extension for newly installed ATA187 and  existing ferntel IP phone?
Is there any Doc showing how to do it which we can study?
5 Replies 5
Jaime Valencia
If you're asking about a shared line, yes.
The CUCM admin guide has an appendix on SIP 3rd party devices config on CUCM, the actual config on the device, you'll have to figure out.
java
if this helps, please rate
What if we are using the CUCM HCS Solution. Can we give the same extension to multiple customers?
Is there a way to configure it?
Thanks.
Sabine
Does not matter if you have HCS, the underlying UC application is still CUCM. Functionality for the application remains the same.
Hi Nipun,
So in the same CUCM, can we have a duplication of extensions(same extensions) in 2 different partitions for example?
Thanks.
Sabine Mattar
Correct. Same patterns/DN can exist taken the fact both are in different partitions.
