Cisco CUCM System version: 10.5.2.10000-5 FAC Issue
mohamed sebaey
Beginner
Beginner
Dear Experts
I have Cisco CUCM System version: 10.5.2.10000-5 , i did configuration for Internation RP with FAC . My issue as below
user A dials international number E.X. 900967XXXXXXXXX  after dialing first 3 digits 900,  it ask to enter the FAC number , After authentication , user have to complete the number to do dial out , finally call go out . I tried CMC , but i got same issue i have to reneter the complete number into two steps and this not logic , any help.
thanks
Manish Gogna
Hi Mohamed,
Please check if the route pattern is overlapping with any other route pattern starting with 900 or 9.! under Route Plan report. You may try unchecking FAC on this 900967XXXXXXXXX route pattern and see if you are still prompted for FAC, this will help you know if the call is hitting the correct route pattern or not. If possible , share the screenshot of the Route pattern and the FAC config.
Manish
