ā01-26-2023 05:55 PM
We currently have 2- Cisco CUSP 10.2 and we have notification that the product is EOL with no replacement. Does anyone have a work around to remove the CUSP or equipment to replace the CUSP? Let me know if you have any questions. I sent config to TAC and they pointed me to Sales support. Any direction would be appreciated.
ā01-27-2023 02:42 AM
It would help to know how you are you using CUSP. I have heard several folks evaluating Kamailio.
ā02-02-2023 07:26 PM
I have the same situation as you John.
but I plan to just removing the CUSP out of the solution and bypass from CUBE to CVP or CUCM and let the CUBE balance by their config.
ā04-02-2024 03:25 PM
We are doing this also (loved SIP Proxy), basically add the CUBEs and CVPs directly in OAMP-SPOG(PCCE), update the routes, the CPS on our CUBEs and SIP Proxies was low enough for this to make sense as a viable option
ā03-13-2023 10:02 AM
We use opensips.org as a replacement, and generally use it to handle failover/ redundancy before calls land on CUBE.
ā11-14-2023 03:50 AM - edited ā11-14-2023 04:07 AM
You may find this information useful:
"Cisco recommends OracleĀ® Communication Session Router, version SCZ9.1.0 GA (Build 46) or later. However, you can also choose to deploy any third-party SIP proxy that suits your requirement." in Contact Center Enterprise Solution Compatibility Matrix Release 12 5
Additionally you can learn more about the Deployment of Oracle Session Router with CCE in Cisco's Deployment guide:
Deployment Of OracleĀ® Enterprise Session Router SIP Proxy in Contact Center Enterprise Solution
Oracle Communications in collaboration with Cisco will be hosting a Live Webinar on Nov 30th on this topic, you can register here:
Seamlessly Transition from Cisco Unified SIP Proxy (CUSP) to Oracle Communications
Hope this helps.
Best regards,
Marco Mouta
Oracle Communications WW Alliances & Technology Partnerships Director
