07-13-2011 05:15 AM - edited 03-16-2019 05:55 AM
Hello Sirs,
Cisco has the solution for IP Phones, Analog phones, but not for a fully featured phone over a 1 pair of copper cable with distances more than 100 metters.
This, in another vendor is called Digital Extension Phone and supports BLF, Boss - Secretary, etc.
One solution is Longth Reach Ethernet, but it is expensive and may be discontinued.
Does any one now a solution to cover this gap in the protfolio?
07-13-2011 05:39 AM
You can use single-pair modem/bridge from any vendor, and place as many full-featured IP phones you want on the other side.
07-13-2011 05:51 AM
I do not understand your answer.
I have CUCM - Network - ............................... - IP Phone
What in the middle?
07-13-2011 12:28 PM
CUCM - Network -Modem-1pair-Modem- IP Phone
07-13-2011 11:52 PM
Then I think that "modem" is EthernetIP - 1pair convesion capable. Do you know a device from Cisco or other vendor capable of this. May be we can have SDSL convertors or something like that, but too much expensive.
07-14-2011 03:02 AM
The ones that cisco makes are routers and expensive. You can use the popular search engine to start looking.
