Cisco Finesse Alert Agent
jschmit
Is there a way to program Cisco UCCX/Cisco Finesse to alert an agent when a call is in queue or if the wait on a queue has hit a specific threshold? If alerts can be created, what type of alerts are available out-of-box?
Ratheesh Kumar
Hi there
I think you might need to create some API programming for this.
Or you could use a wallboard solution ? UCGuru offers a free one
https://www.ucguru.com/free-wallboard-for-uccx/
Other option is  using CUIC and copy/edit the Voice CSQ Summary Report. You can create a threshold that will make the Waiting Calls Red. Creating a permalink to this and displaying it so the agents could see might help.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
