Cisco Gateway does not accept an invite from astriesk
yarob.fathi
Dears,
My cisco  gateway is not allowing a call from astriesk FPBX to pass to PSTN due to:
SIP/2.0 400 Bad Request - 'Malformed/Missing '
Although the first invite looks good to me, It sends a 100 trying then a 500 internal error,then SIP/2.0 400 Bad Request - 'Malformed/Missing URL'
Is there a way to manipulate the invite or what could be a possible solution.
8 Replies 8
yarob.fathi
Received:
INVITE sip:0911111135@10.198.199.1 SIP/2.0
Via: SIP/2.0/UDP 10.198.199.2:5060;branch=z9hG4bK2ed821ba
Max-Forwards: 70
From: "Simplify" <sip:107@10.198.199.2>;tag=as5a972df5
To: <sip:0911111135@10.198.199.1>
Contact: <sip:107@10.198.199.2:5060>
Call-ID: 1c4366e523b2462910f1105657e41880@10.198.199.2:5060
CSeq: 102 INVITE
User-Agent: FPBX-14.0.3.1(13.19.1)
Date: Thu, 09 Aug 2018 23:27:29 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Content-Type: application/sdp
Content-Length: 323
v=0
o=root 1292608259 1292608259 IN IP4 10.198.199.2
s=Asterisk PBX 13.19.1
c=IN IP4 10.198.199.2
t=0 0
m=audio 14328 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
Then the cisco gateway trys:
Sent:
SIP/2.0 100 Trying
Date: Thu, 09 Aug 2018 22:41:32 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M3
Content-Length: 0
Then oops:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:0911111135@10.198.199.1>;tag=3C0AABE0-F
CSeq: 102 INVITE
Reason: Q.850;cause=6
Content-Type: multipart/mixed;boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 281
--uniqueBoundary
Content-Type: application/x-q931
Content-Disposition: signal;handling=optional
Content-Length: 11
.Z
--uniqueBoundary
Content-Type: application/gtd
RLC,
PRN,isdn*,,NET5*,
--uniqueBoundary--
Received:
ACK sip:0911111135@10.198.199.1 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Received:
INVITE sip:10.198.199.1 SIP/2.0
Via: SIP/2.0/UDP 10.198.199.2:5060;branch=z9hG4bK42c0a200
Max-Forwards: 70
From: "Simplify" <sip:107@10.198.199.2>;tag=as19a72c16
To: <sip:10.198.199.1>
Call-ID: 59241e8e291c6ef31cad42d33492282b@10.198.199.2:5060
CSeq: 102 INVITE
Content-Length: 321
v=0
o=root 227366592 227366592 IN IP4 10.198.199.2
t=0 0
m=audio 10728 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
Sent:
To: <sip:10.198.199.1>;tag=3C0AABE8-E6B
CSeq: 102 INVITE
Reason: Q.850;cause=100
Content-Length: 0
Sent:
CSeq: 102 INVITE
Content-Length: 0
ryanticer
Could you attach the gateway config? (sanitize passwords and any public IPs out)
Ryan
I copied the voice related config,should you need anything else please ask, thank you for your concern
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 redirect ip2ip
 signaling forward unconditional
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/1.30
  bind media source-interface GigabitEthernet0/1.30
voice-port 0/1/1:15
 connection plar 107
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
no mgcp explicit hookstate
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
 port 0/1/1:15
 forward-digits all
dial-peer voice 2 voip
 destination-pattern 1..
 session protocol sipv2
 session target ipv4:10.198.199.2
 session transport udp
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 3 pots
 destination-pattern 09........
 port 0/1/1:15
gateway
 timer receive-rtp 1200
sip-ua
 no remote-party-id
 retry invite 3
 retry response 3
 retry bye 3
 retry cancel 3
 timers trying 1000
 sip-server ipv4:10.198.199.2
ryanticer
Nothing major looks off to me in the config. It's one of the URLs it isn't happy about - I think it might be the contact header, but not 100% certain. Next step would be to enable some debugging to see what the gateway doesn't like:
no logging monitor
debug ccsip messages
debug ccsip error
logging buffered 1000000 debug
clear log
<make a test call>
undebug all
show log
Post the show log output here.
*Aug 11 20:06:32.204: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.198.199.2:5060;branch=z9hG4bK3bb682c2
Max-Forwards: 70
Call-ID: 4cdf282a5cbcf327601bc9be1c34c1fb@10.198.199.2:5060
CSeq: 102 INVITE
Date: Sat, 11 Aug 2018 20:52:24 GMT
Content-Length: 352
v=0
o=root 253679241 253679241 IN IP4 10.198.199.2
t=0 0
m=audio 13644 RTP/AVP 0 8 3 111 9 101
a=rtpmap:3 GSM/8000
a=rtpmap:111 G726-32/8000
a=rtpmap:9 G722/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
*Aug 11 20:06:32.204: //-1/E022D3B89F58/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
SIP: (6753) Attribute mid, level 1 instance 1 not found.
*Aug 11 20:06:32.204: //6753/E022D3B89F58/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
*Aug 11 20:06:32.204: //6753/E022D3B89F58/SIP/Error/sipSPI_ipip_update_call_entry:
*Aug 11 20:06:32.204: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count:
Unable to set CHANNEL_COUNT for callid 6753
*Aug 11 20:06:32.204: //6753/E022D3B89F58/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo:
Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
*Aug 11 20:06:32.208: //6753/E022D3B89F58/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 11 Aug 2018 20:06:32 GMT
CSeq: 102 INVITE
Content-Length: 0
*Aug 11 20:06:32.208: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 107
*Aug 11 20:06:32.208: ISDN Se0/1/1:15 Q931: Sending SETUP callref = 0x00A3 callID = 0x8024 switch = primary-net5 interface = User
*Aug 11 20:06:32.208: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00A3
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0180, '107'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0911111135'
*Aug 11 20:06:32.228: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A3
Cause i = 0x8286 - Channel unacceptable
*Aug 11 20:06:32.232: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
*Aug 11 20:06:32.232: Content-Type: application/x-q931
08 02 00 A3 5A 08 02 82 86 0D 0A
*Aug 11 20:06:32.232: //6753/E022D3B89F58/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:0911111135@10.198.199.1>;tag=45C97E04-163A
CSeq: 102 INVITE
Mime-Version: 1.0
Content-Length: 281
--uniqueBoundary
Content-Length: 11
.#Z
--uniqueBoundary
RLC,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*Aug 11 20:06:32.232: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
*Aug 11 20:06:32.236: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.198.199.2:5060;branch=z9hG4bK3376609c
Max-Forwards: 70
Call-ID: 4733837e3b5a139716e7f1cb134b8cc8@10.198.199.2:5060
CSeq: 102 INVITE
Content-Length: 352
v=0
o=root 888189949 888189949 IN IP4 10.198.199.2
t=0 0
m=audio 10138 RTP/AVP 0 8 3 111 9 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
*Aug 11 20:06:32.236: //-1/E027B5919F5E/SIP/Error/sipSPIGetUrlInfo:
Unknown/unsupported URL schema
*Aug 11 20:06:32.236: //-1/E027B5919F5E/SIP/Error/sact_idle_new_message_invite:
Invalid URL in incoming INVITE
*Aug 11 20:06:32.236: //-1/E027B5919F5E/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Sent:
To: <sip:10.198.199.1>;tag=45C97E08-223F
CSeq: 102 INVITE
Content-Length: 0
*Aug 11 20:06:32.736: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Content-Length: 0
Received:
ACK sip:10.198.199.1 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
The 500 error appears to be caused by the next hop circuit refusing the call. The call is being refused due to a "channel unacceptable" error, which roughly translates to a 500 error via SIP back to source:
Once that error is resolved, we can take another look at the 400 error (if it still exists). I recommend checking the settings (or working with corresponding admin to check settings) of the system on the other end of the ISDN circuit to make sure settings are aligned.
Ryan
What is the ISDN channel selection set to ? It should typically be default as in bottom up. Telcos usually do top-down to prevent race around conditions. Also, ensure you don't have a full PRI configured when only a partial is provisioned by your Telco or vice-versa.
This issue was solved, It was a provider issue.
