Cisco h.323 telephones
Aleksei.Zjabkin
Hi everyone!
I can't find any information about what cisco telephones are supporting h.323 protocol.
There was a 7905G h.323 telephone, and now it is end of sales. Replacement is 6921 which is not supporting h323, or it is not written in the datasheet.
So question is simple - what cisco telephones support h.323?
Best Regards,
Aleksei
2 Accepted Solutions
Aleksei
1) You may be able to get the cisco phones working to an AVAYA as SIP, but not as H323 anymore.
2) Yes you can integrate a CME to an Avaya using H323.
Cisco has some great documentation re what they call interoperability on this link.
http://www.cisco.com/en/US/netsol/ns728/networking_solutions_program_category_home.html
You need to have clue as to what the Cisco and the AVAYA devices are:-
E.g.
CME
http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805bd0ac.html
Then say you wanted:-
Cisco CME to AVAYA S8700 using H323
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/467019.pdf
You probably wonmt get the exact version numbers you want but the basic priciples will be very similar.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Answer is - NO.
Cisco phones support it's proprietary SCCP to work with Cisco UCM/CME/UC500 and also support SIP to maintain the standard.
The oldie Cisco 7940/7960 might support the SIP firmwares to connect with Avaya IPO/CM but that's not officially supported by Cisco - so it's not worthy to discuss here.
ATA186/187 is an analog gateway which supports H.323 but this is to connect your analog phones and fax machines only. It has one RJ45 port to connect the Ethernet cable and at behind there is 4pin RJ11 - so forget the ATA186/187.
As Alex asked you - if you are looking for integration between Cisco UCM/CME/UC500 to Avaya IPO/CM by H.323 protocol then forget what I explained so far. Answer for that question is - YES.
HTH.
7 Replies 7
acampbell
Aleksei
I think you are out of luck nowadays.
The 7905 has gone.
You could use an ATA186 with H323 software.
The last relaese was :-
ATA Version 3.1.2 software for H.323
  ata_03_01_02_h323_040927_1.zip
3rd October 2004
Alex.
Hi acampbell,
We have avaya pbx and we need to know how can we interconnect avaya and cisco phones using h.323.
So Im searching now for h.323 phone.
This ATA186 is some kind of modem? How can I integrate it in my solution?
Aleksei
Aleksei
Are the Cisco phones working to a CUCM or CCME ?
Do you want to connect the CUCM (or CME) to the AVAYA ?
Or are you trying to get Cisco phone to work with the AVAYA.?
Alex.
As far as I understand, we need to get Cisco phone to work with the avaya.
Is it possible to connect CME and AVAYA using h323?
Aleksei
Aleksei
E.g.
CME
Alex.
Answer is - NO.
HTH.
Aleksei.Zjabkin
Thanks a lot,
Aleksei
