208
Highlighted
Beginner
Cisco headset 561 auto answer disable
Dears,
We have recently purchased fee headsets for our customers. The issue us that the incoming calls are answered automatically when the user remove the headset from it's base. It impacting the caller experience. So is there anyway that I can disable this feature and only answer when the user manually accept or press the answer button . How to disable the autoanswer while remove it from the base unit.
Cucm 12.0
Everyone's tags (2)
2 REPLIES 2
Highlighted
Beginner
Re: Cisco headset 561 auto answer disable
Please check this;
Device --> Phone and find desired device/phone
Once phone comes up, click on extension number and you will see Auto Answer options.
//Please always rate helpful comments//
Highlighted
Beginner
Thanks for your response.  The auto-answer is already off.
This is a feature in Cisco 561 with a standard base from the firmware release 1.0(2). I am looking for any option to disable this feature.
As per the 561 standard base firmware 1.0(2) release document,
Enhanced Standard Base Functionality
You can answer and end calls when you lift and set down your Cisco Headset 561 and 562 on the Standard Base.
Now I want to disable answering the call when the user lifts the headset from its base. I want the users to manually press the answer key to answer the call.
Any option to do that.
Shalid
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
