Cisco Headset 562 SB with/for Supervisor function
Hello
We like to use the new Cisco Wireless Headsets and the difference between Standard and Multibase is pretty clear but I could not found any information about the "Supervisor" or "Coaching" function.
This is important for our Contact Center People. We need to be able to listen to calls and teach the employees. Other brands,like Jabra Engange 75 are really simple to pair a second Headset and to listen to the call. We are looking for the same function within the Cisco Wireless Headsets...
Anybody can help me or does know how it works?
Thank you very much for any suggestions.
Best regards,
Pascal
1 REPLY 1
Highlighted
PTS Beginner
Beginner
Re: Cisco Headset 562 SB with/for Supervisor function
Your requirement of monitoring agents using Cisco IP Phones call can be fulfilled by the 3rd party solution Parsec's "MARS Silent Monitoring"
http://www.parsec-tech.com/parsecapplications.html
You can also write to info@parsec-tech.com
Content for Community-Ad
July's Community Spotlight Awards
