01-30-2011 02:57 PM - last edited on 03-25-2019 08:04 PM by ciscomoderator
Hello all,
I'm not sure if I am beating a dead horse on this one, but I running into some trouble trying to get my IAD2431-16fxs to communicate successfully to my old mid 60's Western Electric 1A2 KSU. As it stands I have to of the FXS ports from the IAD configured with extension numbers and hooked up to line 1 and 2 on the KSU. I have the IAD set to PLAR to ring the KSU lines. The trouble I am having it that the call is successful for about 2 seconds and then the KSU drops the connection. I was referring to artical https://supportforums.cisco.com/message/395939# and someone mentioned that there are disconnect supervisory problems and that loop start and ground start need to be configured on the KSU, but I was looking at the manual I have for this unit and it does not mention anything about being able to change those. Just though I would through this one out there before I keep trying to do the impossible. Any input is appreciated.
-Jeff
Solved! Go to Solution.
01-30-2011 07:26 PM
Under voice-port, try "no battery-reversal".
01-30-2011 07:26 PM
01-30-2011 07:42 PM
Awesome, That did the trick. Thank you very much.I can now sustain a call to and from the KSU.
One other issue, the KSU does drop the call when I use the hold button on the 1A2 phones, and the phones attached to the KSU will not ring. If you have any thought on that It would be a great help.
Thank you very much
-Jeff
01-30-2011 07:57 PM
Check grounding ? Perhaps time to evolve the KSU into something from this century ?
Thanks for the nice rating and good luck!
