01-05-2010 11:38 AM - edited 03-15-2019 08:57 PM
One of my customer is looking to deploy Call Manager solution. They are using Nortel CS 1000M, SRG 50 Gateway and Nortel IP phones. I am looking for a solution to use existing Nortel phones, switches and SRG 50 gateway with Cisco Call Manager, Is it doable?
Thanks.
01-05-2010 11:46 AM
No.
Only use Cisco phones and switches with Cisco Call Manager.
01-05-2010 10:15 PM
Can I use those Nortel equipment at branch location using H.323 gateway protocol.
Thanks.
01-06-2010 05:13 AM
You could setup H.323 between PBX and CM.
Recommend you engange a certified dealer or reputable consultant, as it is not a task for the inexperienced.
Remember to rate useful posts clicking on the stars below.
