Cisco IOS Homogeneous Video Conference Bridge
Labanelamia
HI,
I have to configure video conference with :
-CISCO Router 2911
-pvdm3-16
-Cucm version 10
-unity connection
-21 ip phone 8945
 so i have looked for a solution to do a video conference without the server telepresence:
i have applied the following solution:
/////////////////////////////////////////////// 2911
Voice card 0
Dsp service dspfarm
Dspfarm profile 1 conference
Codec g711alaw
Maximum session
Associate application sccp
No shut
Sccp localo loopback 0
Sccp ccm 192.168.1.101 Identifier 1 priorty 1 version 7.0+
SCCP
sccp ccm groupe 1
Bind interface loopback 0
associate ccm 1 priority 1
Associate profile 1 Register cfbrouter
////////////////////////////////////**Configuration cucm serveur
Media resource --->conference bridge
conference bridge name ---> cfbrouter
Create Meet-Me Number/Pattern
Call Routing > Meet-Me Number/Pattern
2000
Device > Device Settings > Common Device Configuration
COMMDEV
Cisco Unified Serviceability
Turn on Cisco IP Voice Media Streaming App
The video conf still not working, can i get some help to troubleshoot this issue;
Thanks.
2 Accepted Solutions
As Jaime said, you need a video  CFB. The video CFB goes something like this:
voice-card 0
voice-service reservation X
dspfarm
dsp services dspf
dspf pro 1 con vid homo
codec g711u
codec h264 cif frame-rate X bitrate X
m s 4
a a s
no shut
I copied this from one of my production routers, please do not copy paste unless you fully understand every line and the effect this will have on your network.
FG
That you configured a voice CFB, not a video CFB, all you get from what you configured, is voice conferences.
Actually nevermind, you need a another video CFB, this has been deprecated, PVDM3s are no longer supported for video on ISR G2
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/bulletin-c25-735945.html
That's probably the reason why I couldn't find any references for config.
java
if this helps, please rate
11 Replies 11
Jaime Valencia
Because you configured a voice CFB, not a video CFB.
java
OK end ??
java
Hi Jaime
Which CFB do you recommended i can see pvdm3-128 should be support video CFB am i right ?
But you say pvdm3 no longer supported video CFB
Whicg pvdm or product supported by cisco can you please provide me info ?
It WAS supported for video, not anymore.
You cannot do anything with PVDMs, you need a vTP or an MCU for video conferences (There's a whole doc on video preferred architecture on cisco.com you might want to review). No way around that, you might still find references for the config and do it, but you'll have absolutely no support from Cisco with anything regarding using the PVDM3 as a video CFB.
java
Thanks Jaime for explanaition.
Is ıt works with previous ios 15.5.3
Hi Jaime,
hope this finds you good,
could you please provide any link or document says that i can't anymore use the PVDM as video conference resource, i have DX80 will register on CUCM 11 and customer asks to use the PVDM?
also if you please tell is there any recommended steps or configuration to make DX80 register on CUCM?
I already posted the link in a previous response...
About the DX80, just choose the right device type on CUCM, depending on what the device has, either Android or CE, the rest of the configuration is the same as any other device.
java
Thanks Jaime
Now i have dx80 with ce software when i add on cucm 11 there is no ce or andriod
And in the divce defaults there is no load id for dx80 or dx70 it only found for dx650
Now can i add dx80 as ce is it ok
And what i miss if i regestir it as ce not andorid
voice-card 0
dspfarm
dsp services dspf
codec g711u
m s 4
a a s
no shut
FG
