05-08-2012 07:00 PM - edited 03-16-2019 11:03 AM
Hi Friends,
We are running Cisco IP Communicator v2.X but the issue is we are getting Blank screen.
The operating system is windows XP...
Could you please let me konw if any faced the issue before.. Your answer is much appriciated...
05-08-2012 07:27 PM
Are you using cucm or cme? What version? Is it defined with proper tftp ip address?
05-08-2012 07:33 PM
Try to upgrade your JAVA in the operating system.
Ronak Patel
05-09-2012 05:53 AM
hi
what is the connectivity between pc and server. Is there any vlan, check the tftp service in server is active,
also check auto registration is enable or not. check all the java plug-ins in pc was installed or not.
Praveen Kumar GVK
05-10-2012 08:52 AM
We are running CUCM 8.5 version and the IP communicator version is 7.0.4.0 with win 7 OS.
11-05-2012 09:13 AM
Kulasekararaja -
Any resolution to this issue?
Amir
05-27-2013 01:14 AM
Reinstall the cipc was solved our same problem.
