Cisco IP Communicator doesn't register in VPN (Cisco VPN client)
phil.garrelhas
We currently have a Cisco 2901 running Cisco Unified Communications Manager Express.
We're running Cisco IP Communicator 2.1.2.0.
We're running Cisco VPN Client 5.0.07.0410
We have a Cisco ASA Firewall
When I launch CIPC, it becomes stuck at the "Registering" process only when I am VPNed into the network.....using both wireless or a cable.
What I've done:
1. I can ping the Call Manager/TFTP successfully.
2. I have added the MAC info for the wireless card and the Cisco VPN adapter to the call manager.
3. I have the TFTP IP set in CIPC under  Preferences->Network->TFTP Servers.
While it's "Registering", if I disconnect from VPN and plug into my local network, it registers in a second.
What am I missing here?
Phil...
18 Replies 18
Davidwagman1
Level 7
Level 7
Phil,
Is there a policy in your ASA that may be blocking the traffic?
Best,
David
Hi David,
No, there are no rules blocking traffic.
Hi Everyone,
Under "audio" , I went to the network option and I got a default IP address in the  "use this address" option which corrected my issue.
Hi Phil,
In your CIPC client make sure that you select "Cisco VPN Client Adapter" to be used by CIPC and not your wireless adapter.
open the command prompt as an administrator
e.g  go to all programs > accessories > command prompt > rightclick > open as administratior
on the c:\ prompt write the follwoing command:
C:\>netsh int tcp set global autotuninglevel=disabled
Tried that command, and still the same results.
Hi Mohammed,
I've already added both the wireless and Cisco VPN adapter mac addresses to my call manager and tested in CIPC for both. Doesn't pass the "registering" phase.
Phil,
I assume you are able to access other network resources over the VPN? Do you see the traffic from CIPC on the network with wireshark, or on the CME box - debug tftp events ? Can you ping the VPN client from the CME router?
Best,
David
Hi David,
Yes. I can access all other resources over the VPN network. And yes, I can ping the VPN client from the CME router and vice versa.
Using Wireshark, I see several read requests followed by, no such file.
102 68.474312  TFTP 73 Read Request, File: CTLSEPA4BADBDE33E5.tlv, Transfer type: octet
103 68.500206  TFTP 59 Error Code, Code: File not found, Message: No such file
The files exist, otherwise I'd see the same errors when I'm connected to my network without VPN.
Thoughts?
Phil
Hi David,
I was wondering if you had a chance to see my reply to this.
I'm able to ping from the client to the cucm and vice versa.
Any other ideas?
Phil
Hi Phil,
I am not talking only about cucm side. In cipc client you need to set the source interface under preferences menu. There you shld select vpn client interface. Then you shld configure vpn mac in cucm.
Hi Mohammed,
Thank you for the response.
And yes, I changed the source interface in CIPC as well as in CUCM.
Phil
Hi Phil,
I do not have that much idea on ASA but for VoIP protocols we need to enable inspection of protocols.
Please find the URL .
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
regds,
aman
All the proper protocols seem to be set up on my ASA.
The only errors that I see in Wireshark when connected through VPN, are:
