07-07-2014 05:54 AM - edited 03-16-2019 11:19 PM
Good morning, I've a callmaanger 10.0.1 and all works wel.
I've registered a cipc and it works wel, but on the phone display appears Always the service menu. (see attached file)
Eachone can help me?
Thanks in advance
Giancarlo
Solved! Go to Solution.
07-07-2014 06:56 AM
This is probably because you are using https services, change them to http and it should be resolved.
Chris
07-07-2014 07:14 AM
That's part of the CUCM 10.0 self-provisioning.
CIPC will always show a blank services window for the self-provisioning since it doesn't support HTTPS.
Under the phone configuration, remove the Idle URL and then save and reset.
You can update the Universal Device Template you're using for auto-registration to not contain the Idle URL if you are not going to be using the self-provisioning feature.
07-07-2014 06:56 AM
Chris
07-07-2014 07:19 AM
Hi at all I'm trying to check alla suggestion.
Just a few minutes....
07-07-2014 07:21 AM
The self-provisioning service in CUCM 10.x only runs as HTTPS.
07-07-2014 07:14 AM
07-07-2014 07:17 AM
giancarlo
