01-20-2011 11:55 PM - edited 03-16-2019 03:00 AM
We are about to deploy Cisco IP Communicators in our organisation. And in that regard a few questions arise.
What happens when the laptop with the softphone is shut down? I suspect you will get an error when the number of the softphone is called.
Is there anyway to prevent that? One solution could be to instruct the users to forward all calls before they close there laptops. But that is not a good solution in my opinion.
Thomas
Solved! Go to Solution.
01-21-2011 12:04 AM
For a detailed answer you need to let us know which call control product you have - e.g. CUCM 7.1.
Assuming that you have this version calls would be treated according to the Call Forward Unregistered settings on the line allocated to the softphone.
This could be set to forward calls to voicemail, an internal destination or an external number such as a cellphone.
01-21-2011 12:04 AM
01-21-2011 12:26 AM
Hi James,
Thanks for the quick reply. That was exactly what I was looking for.
We are using version 7.0.110000-2 by the way.
Thomas
