Cisco IP Communicator?
HI, I have installed CISCO IP Communicator onto a user laptop and after first installation it worked fine.
now each time the user logs in and launches the app, the app opens but the display remains black and doent'nt show any text.
if i log onto the laptop as a different user the display shows fine.
i have reinstalled to see if it resolved with now luck.
5 Replies 5
hzaben
whats the version of OS hosting the CIPC ? whats the version of CIPC ?
can you right click the CIPC and select run as administrator ?
thanks
Haitham
I've the same issue. My display is always black.
I'm using Windows 7 64bit.
I'm admin and also started the tool with admin rights.
The version I'm using is 7.0.6.0.
7.0 is not supported on 64 bit systems:
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-communicator/data_sheet_c78-505261.html
you might need to bring it to 8.6 and run it in compatibility mode
Please remember to rate useful posts, by clicking on the stars below.
That's interesting, because it was running before. I can download the version 8?
Hi Chris,
Yes. You can downlaod the latest available version of CIPC from the below link:
https://software.cisco.com/download/release.html?mdfid=278468661&softwareid=282074237&release=8.6(6)&relind=AVAILABLE&rellifecycle=&reltype=latest
Rajan
Pls mark all helpful posts by clicking the star
