Cisco IP communicator
FrancisRK
Hi, iam using cisco IP communicator ver. 8.6.6.0. facing some issues.  what is the PC requirements for proper functioning of IP communicator? could anyone help.
b.winter
As always: check the release notes ...
https://manualzz.com/doc/24217259/release-notes-for-cisco-ip-communicator-8.6.6
IPC is end of life and is not further maintained by Cisco. You should switch to Jabber.
Please switch to Jabber because CIPC is no longer supported.
You may have to try  running it on Windows compatibility mode.
Response Signature
