The Cisco IP Phone 7941, at our site is showing an error while booting.
Error: On power on the Display shows Cisco logo. Other than this the two line button keep glowing. The headset button glow is green and Mute in Red colour.
This symptoms not allow to complete boot sequence of the phone.
Kindly suggest for the same.
Thanks in advance.
As I re-resurrect this old thread. Heh.
I have some 7941s that need to be moved from one network to another.
I read this procedure, and tried it on two phones, both say "upgrade" now.
The 7940s I have are resettable without having to reload the phone's firmware from TFTP, but it seems the 7941 cannot be reset to defaults without having it on a network with the TFTP and parameters.
Which I don't have for the new network these are eventually going to be deployed on.
So is there no way to reset the phone without reloading the whole thing?
I just wanted to blow out old address books (personal employee information) and network settings leaving these phones in a state that they can be easily deployed later.
Thanks in advance.
Hi Steve
Bad you for creating a zombie.
I'll try for a headshot :-)
Basically you don't want to factory reset if you are going to a network where TFTP isn't set up propertly for these reasons:
1) TFTP/DHCP should always be set up properly.
2) TFTP/DHCP should always be set up properly.
3) TFTP/DHCP should always be set up properly.
4) Personal address books aren't stored on the phone. They are part of the CUCM database, so you take away the phone, they forget.
5) You can clear the 'network' config by going into the network config subment and doing an 'erase' there. Again, if DHCP etc is configured properly on the network you are going to, it's a non-issue as all that stuff gets picked up from the new LAN. If DHCP not configured properly, you need to configure the IP stuff manually so again, it's a non issue.
Regard
Aaron
Aaron,
Yeah, created a zombie. My bad. Shoot for the headcrabs.
It seems that address books are stored on 7940s, which I am much more familiar with. Well, AFAICT.
My surprise they are not on 7941s.
Or so you say.
However I have missed, received and placed calls that are there and should be erased.
These came from another division and no one knows the pw to reset network settings.
Unless there is a default pw, these all say locked. Well, on second look **# works.
But there is no default command that I can see.
So it's kind of a PITA to have to erase parameters from a number of used phones.
Which is why the reset was necessary. Some are also in other languages at this time.
Like Japanese. Things certain engineers were comfortable in. Gad.
None of the phones have local storage for numbers - they are all stored in CUCM.
Language is downloaded from the target system based on the config there, unless the target system is broken.
Same for firmware.
Same for network settings.
So there is no data security stuff to worry about... and no setting stuff, or language stuff, unless your target system is broken. And if it is broken... fix the target system, don't reset the phone.
Aaron
Aaron,
The target system isn't broken, it's just not on site.
I have suggested we set one up here.
That has met with lukewarm response. Heh.
Is there an easy way to put new firmware on these phones without the CUCM being on site?
We have all local ips naturally, part of our security plan.
These phones don't seem to get an IP from our local DHCP.
They need the call manager, I guess.
If there is only one 7941 phone which is not booting properly and other phones are working fine
then we can try factory resetting of that particular phone
To initiate the factory reset:
The code for the soft factory reset is: 123456789*0#
A soft reset does the following:
The code for the total hard reset is: 3491672850*#
A total hard reset formats /flash0 blowing away everything except CNU. All settings and personalization of the phone is removed.
The code for the network preservation hard reset is: *7412369#085
And it also does a complete format of /flash0 - yet it preserves the network settings so that after the format, any static IP and other network settings are preserved. The settings are stored in volatile RAM, so it is important to not remove power to the phone during this process
For CSCsi60439 reference please see document EDCS-609633.
There are a number of prerequsites that are necessary for a successful factory reset.
The Total Hard Reset process posted above worked for me.
I had a 7941 that did not boot at all and had a random pixellated display.
The Total Reset wiped the phone and allowed the firmware to be upgraded.
Phone now works perfectly.
After doing a Total Hard Reset, which procedure should be done to put new firmware on the phone without a CUCM, it is possible with TFTP only?
Best Regards
Carlos
Thank You Vivek. The total hard reset worked for me too. I never knew about this procedure until now. The phone I was working with was a 7962 stuck on 'Upgrading' and would not load the new image. It took a few minutes and had me worried when the screen went blank for a couple of minutes but it eventually came back to life, rebooted and upgraded immediately.
Much Apprectiated...
Hi Vivek after resetting 7940 cisco, how can i know the status in IP Phone weather the phone reset properly or not because i am getting "XML ERROR[4] PARSE ERROR" so i am confusing because its not showed as "Upgrading" so please guide for the next process.
You can start a new discussion with details like the original issue, what exact steps you performed based on this post and what is the exact error on the phone display right now. Also add details like the cucm version, firmware version on the 7940 and the firmware defined in device defaults on cucm page.
Manish
I did below procedure:
1.Error is Now "Blank Screen"
2. Another IP Phone i have done same procedure as above,that IP Phone stuck in "Upgrading"
As what Manish said, start a new thread.
This thread is >7 years old and are irrelevant to your issue.
