04-24-2013 06:11 PM - edited 03-16-2019 04:59 PM
Cisco Unity express Version 7.0.
A Cisco phone model 7945 with a particular number is always showing a wrong indicator , whenever the user does not have any voicemail in the Mailbox the indicator and the symbol shows or will be in ON state.
We have refreshed the VM indicator then also after one day the same issue happened.
We have recreated this particular extension and VM box still the issue persists kindly someone help me with this issue.
Solved! Go to Solution.
05-21-2013 04:29 AM
Update CUE software. Then use "unsolicited notify" configuration.
04-24-2013 07:06 PM
Does the phone have a second line? If so, the MWI light might be on because of VM left on the second line.
04-25-2013 07:46 AM
no there is no second line for this phone only one line, Once we refresh the status from the cue THE INDICATOR goes to off and then after sometime or some hours it will happen again.
04-25-2013 07:50 AM
I have a couple of questions:
1. What type of integration with voicemail is this, SCCP or SIP?
2. If SCCP, does the end user have access to the MWI on and off numbers, is it possible that they are dialing this number on accident or without knowing what it does?
04-25-2013 08:52 AM
Hi John,
The integration is sccp.
But there is a very less chance for that point you . but i will not neglect this issue. I will test and confirm it.
04-29-2013 11:11 PM
Hello John,
The issue still presists.
the mailbox does not have any VM but the indicator will pop up.
do you have any suggestion.
05-21-2013 12:42 AM
Hello John,
05-21-2013 04:29 AM
