Cisco IP phone 7965+7916 Expansion Module BLF configuration using CLI
Tamas86
Beginner
Beginner
Hello everyone!
Sorry for my English. For learning purposes, I put together a small telephone network. Everything works fine. I want to try the BLF function and understand it, but I'm doing something wrong. Unfortunately, I do not have the option to install a GUI interface (CUCM GUI), I can only configure the system via the CLI interface. There are 4 telephones in the network, which are 7945 type and 1 with 7965+7916 module.
1. For example, if you call 101 from 103, the LED next to extension 103 on the "monitor" phone 105 lights up, so that's OK
2. If, for example, 101 calls 103, the "monitoring phone" 105 will also ring and indicate that 101 is calling 103, but I don't want this, only the LED lights up. Can the bell be turned off?
3. The led does not work on the 7916 expansion module, how can I set this correctly from the CLI interface? Possible?
Thank you in advance for your help!
Tamas86
Beginner
Beginner
I found the solution to the mentioned problems: the "button" was not set correctly in the configuration.
Tamas86
Beginner
Beginner
