Cisco IP phone 8845 integration with cucm 10.5.2.11900-3
I need to integrate 8845 video phone to 10.5.2.11900-3 as I can't see it under device
I'm planning to do a Device Pack update using cmterm-devicepack10.5.2.13050-1.cop.sgn
I would like to avoid a SU at this stage
Anyone had done it?
Any advice?
Thank you
Manish Gogna
Hi Louis,
I don't see the device pack 10.5.2.13050-1 on cisco.com but even the device pack 10.5(2)(13049-1 has support for 8845 as shown in the read me file below
http://www.cisco.com/web/software/282074299/130594/cmterm-devicepack10.5.2_13049-1_Release_Notes.pdf
So, you can install any of the latest device pack on all nodes and reboot the cluster and you will be able to add 8845 IP phone.
Manish
5 Replies 5
Manish Gogna
Hi Louis,
Manish
Deepak Rawat
As Manish correctly mentioned, apply the latest DP and you should be good then
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C2DC6BBD_00
Deepak
Hi Deepak,
Instead of installed Dp why not just install
Description:    8845 and 8865 SIP IP Phone firmware files only - Compatible CUCM Versions: 8.5(1)+
Release:    11.0(1)
Release Date:    24/Nov/2015
File Name:    cmterm-8845_65-sip.11-0-1-11.k3.cop.sgn
Size:    64.68 MB (67825963 bytes)
MD5 Checksum:    4bccf1c913d4b7e2cca6c01ebf02a09d
SHA512 Checksum:
659cbf684c81299dda259e6607b0138bb077bddc09b61a9d6c383b7ec6e037c55d003dade5c5af4ade44379ae2f94f29ed93eb27e9b5d40c0c2be2254253cd22
thanks
Hi Louis,
If the device is not listed in the dropdown menu on cucm you need the device package to enable that option, simply installing the firmware file does not work.
Manish
http://docwiki.cisco.com/wiki/CUCM_FAQ#Adding_support_for_new_endpoints
Deepak
