Cisco IP phone consumption license
Nizam.Ahmed
Hi Expert,
Would you tell me the license consumption of different models of IP phone as well as video phones.
Kazi Nizam Nizam Uddin Ahmed
5 Replies 5
Rajan
Can you specify what is your CUCM version because licensing model differs with versions.
Rajan
Hi Rajan,
Thanks for your reply.
The CUCM version is 11.
Additionally would you please tell me the parameters for which the licensing depends on?
Nizam
[+5] to Rajan.
Dx650/DX70 /DX80 /9951/9971 require UCL Enhanced license .
You can check datasheet for respective IP phone model and look for license.
You need to have Prime License Manager.After successful installation of CUCM 11, you  need to login into PLM to generate license request so as to get permanent licenses before the grace period expires.
Also, if Owner Id of single user is  associated with two devices , enhanced plus UCL would be consumed for more than 2 and upto 10 , it is CUWL Standard.
regds,
aman
Thanks Aman [+5].
In addition to the info provided by Aman, you can get more details reg license types in the below link:
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-licensing/product_solution_overview0900aecd806cc7a4.html
https://supportforums.cisco.com/document/9869241/understanding-enterprise-license-manager
Rajan
This explains the license calculation clearly
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117600-technote-cucm-00.html
