Cisco IP Phone Firmware upgrade
techguy
Level 4
Level 4
I have the following files on my router's flash.
apps42.8-4-1-23.sbn
cnu42.8-4-1-23.sbn
cvm42sccp.8-4-1-23.sbn
dsp42.8-4-1-23.sbn
jar42sccp.8-4-1-23.sbn
SCCP42.8-4-2S.loads
term42.default.loads
term62.default.loads
and
apps42.9-1-1TH1-16.sbn
cnu42.9-1-1TH1-16.sbn
cvm42sccp.9-1-1TH1-16.sbn
dsp42.9-1-1TH1-16.sbn
jar42sccp.9-1-1TH1-16.sbn
SCCP42.9-1-1SR1S.loads
How can i make sue that cisco ip phone 7962 phones take latest firmware which is 42.9. Right now they have 42.8 firmware?
Rob Huffman
Hi Omer,
The phone firmware is specified in Step # 5 below;
SUMMARY STEPS
1. enable
2. configure terminal
3. tftp-server device:firmware-file
4. telephony-service
5. load phone-type firmware-file
6. create cnf-files
7. end
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1070512
Cheers!
Rob
8 Replies 8
Rob Huffman
Hi Omer,
SUMMARY STEPS
1. enable
6. create cnf-files
7. end
Cheers!
Rob
So, i have 6 different files in my flash. I have to give tftp-server command 6 time and then load command 6 time???
That is correct,  You will have a entry per firmware file.
HTH,
Justin
i am getting the following error. When i am putting command
Router-CME(config-telephony)#load 7962 dsp42.9-1-1TH1-16.sbn
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually
Here is an example for a 7975 phone.
tftp-server flash:/PHONES/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/PHONES/7975/term75.default.loads alias term75.default.loads
Telephony-Service
load 7975 SCCP75.8-5-3S
HTH,
Justin
Same error
Router-CME(config-telephony)#load 7962 SCCP42.9-1-1SR1S
Updating CNF files
CNF files update complete for phonetype(7962)
1. configure max-dn, max-ephone
2. configure time (clock set or ntp)
3. ip source-add port
4. load and create cnf
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_configuration_examples_list.html
I am getting the error but it worked for me. Thanks ROB and all.
Can i repeat the same process for cisco 7911 too? Or it works for only one phone model.
Telephony-Service
and same time i do for Cisco 7911
