09-18-2019 10:21 PM
Hello friends.
How can i set new IP Address on SPA-301 IP Phone,using phone buttons?
Solved! Go to Solution.
09-20-2019 07:47 PM
Sorry, I missed the matter. You can't configure IP via IVR. You can discover current IP via IVR then use WWW UI to configure it. But it's rather recovery procedure - phone uses DHCP (by default) to obtain IP address, thus IP is assigned by it and you need no IVR/WWW to configure it manually. Or you can arrange complex zero-touch deployment environment. Even virgin phone can be fully provisioned with no manual intervention of user required.
09-19-2019 04:15 PM
Did you missed Using the Interactive Voice Response Menu on the Cisco SPA301 paragraph of User Guide ?
09-20-2019 08:40 AM
I am already seen that paragraph,but i didn`t seen,that how i can change my Phone IP address from 0.0.0.0 to other IP.
09-20-2019 07:47 PM
09-20-2019 10:32 PM
Thank you dear Dan.
