Cisco IP Phone :Third party call controll(3PCC)
faraz1234
We are trying to register 8841,8861 IP phones to a third party PBX but unable to succeed:
Model:8841,8861 with 3PCC firmware.
We have pointed the option 150 to a PC where we are running the tftp server,this tftp server has the script file CP_8841_3PCC.cfg.(Attached).
I have taken copy of sample script from the following Cisco document and edited it as per our requirement.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-series/3pcc/english/provisioning-guide/provision/spc_ex.html
We  tried to do the manual re-sync with this script for provisioning but we are getting error bad file format.(Attached)
Please share correct procedure for this if you have done this.Your help will be appreciated.
Brian Meade
Level 7
Level 7
Does the 3PCC firmware still allow you to view console logs on the phone webpage?  If so, that will probably give more info about what specifically it doesn't like about the file format.
