Cisco IP phone unable to dial (787) area code number. CUCM 12.0.1 ver.
adw8
Beginner
Beginner
Cisco IP phone unable to dial (787) area code number. CUCM version 12.0.1.
787 is PR area code
User tried to dial 81-and then the complete number.
Please advise
Looks clear enough that you’re not hitting a dial peer. Would you please mind to share the complete running configuration and the output of these two debugs running simultaneously, debug ccsip message and debug voip ccapi inout? Please attach the this as separate files, not as text directly in a response.
Response Signature
6 Replies 6
b.winter
VIP Advisor VIP Advisor
VIP Advisor
If you cannot dial a number, you need to check the dial-plan in CUCM and also the CSS of the phone / line.
I check through Route Plan report and there is a route plan for 787 area
I did test calls from my phone and checked the cube logs and it showed me
InternalErrorCode=1.1.128.11.5.0
sh voice iec des 1.1.128.11.5.0
IEC Version: 1
Entity: 1 (Gateway)
Category: 128 (Destination address resolution failure)
Subsystem: 11 (C SCRIPTS)
Error: 5 (No dialpeer match)
Diagnostic Code: 0
Response Signature
Yes, you were correct. Any calls made to the 787 area code were not hitting the dial peer groups in the CUBE. The outbound calls were being rejected by "404 Not Found" Error because there is no matching outbound dial-peer on the CUBE for 1787xxxxxxx. There is a dial peer configured on the CUBE for calls to the PSTN which was using e1164 pattern map 2 to route the calls.
The call that arrives from the CUCM using 1787xxxxxxx and not 81787xxxxxxx.
Fixed the Route pattern error in CUCM which resolved the issue.
Thankyou and Appreciate all your support.
Roger Kallberg
VIP Expert VIP Expert
VIP Expert
Recommend you to use DNA to see what the number analysis in CM states when making the call to the number.
Response Signature
Recognize Your Peers
