10-18-2020 03:48 AM
Wallpaper or IP phone background change in bulk using Common Phone profile in CUCM is possible only for 88xx series phones. However in 79xx and CIPC; user have to select the background from IP phone's settings menu. But we want to push the wallpaper from CUCM using common phone profile. Does anyone know have any solution for 79xx series and CIPC phones?
CUCM version 11.5.x
Solved! Go to Solution.
10-19-2020 02:53 AM
10-19-2020 11:10 PM
10-19-2020 02:53 AM
10-19-2020 03:34 AM
Thanks for replying.
I would like to know what is the default path for the image file "CiscoPhoneLogo.png" in CUCM nodes. Because for different phone models, there are different paths
Example for CP-7945 path is Desktops/320x216x16, for CP-8865 is Desktops/800x480x24.
10-19-2020 03:39 AM
10-19-2020 03:58 AM
Thanks, I will test and let you know.
10-19-2020 10:59 PM
Hi, I have uploaded the image "CiscoPhoneLogo.png" in "Desktops/320x212x12" for CIPC and put the image name in common phone profile. assigned the common phone profile to one CIPC phone, but no luck. Still user have to select the image from settings, it is not getting reflecting automatically in CIPC background.
10-19-2020 11:10 PM
10-20-2020 12:17 AM
For 7945 it is working. Really appreciate your support on this.
10-20-2020 12:50 AM
10-19-2020 03:40 AM - edited 10-19-2020 06:57 AM
Please have a look on below bug.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCud67313/?rfs=iqvred
10-19-2020 04:01 AM
Thanks, I am aware about this bug, looking for alternate solution.
10-19-2020 06:54 AM
Nithin, please refrain from posting images of the actual bug information and simply direct people to the bug via the URL, that information requires people to login in order to see it and you posting it like that bypasses such authentication mechanism.
10-19-2020 06:58 AM
Noted and Removed the image.
12-21-2022 08:50 PM
Dear sir,
could you please share screenshot of the process or a video because i tried in our cisco 7945 ip phone but its not working
