Highlighted
Beginner
Cisco IP phone wallpaper changing
Wallpaper or IP phone background change in bulk using Common Phone profile in CUCM is possible only for 88xx series phones. However in 79xx and CIPC; user have to select the background from IP phone's settings menu. But we want to push the wallpaper from CUCM using common phone profile. Does anyone know have any solution for 79xx series and CIPC phones?
CUCM version 11.5.x
2 ACCEPTED SOLUTIONS
Highlighted
VIP Advisor
You can set it as default wallpaper and it will populate automatically
without user intervention. Just save your image with the name
'CiscoPhoneLogo.png' and assign this name to the common phone profile >
background. Finally, use bulk to assign this profile your phones.
**** please remember to rate useful posts
Highlighted
I haven't tried it on CIPC but I know it's working on 7945/65. Give a try
for one of them as see if it works.
12 REPLIES 12
Highlighted
VIP Advisor
Highlighted
Thanks for replying.
I would like to know what is the default path for the image file "CiscoPhoneLogo.png" in CUCM nodes. Because for different phone models, there are different paths
Example for CP-7945 path is Desktops/320x216x16, for CP-8865 is Desktops/800x480x24.
Highlighted
The path is same depending on the phone model. See this doc.
https://community.cisco.com/t5/collaboration-voice-and-video/implementing-phone-background-images-for-cisco-ip-phones/ta-p/3115140
Highlighted
Thanks, I will test and let you know.
Highlighted
Hi, I have uploaded the image "CiscoPhoneLogo.png" in "Desktops/320x212x12" for CIPC and put the image name in common phone profile. assigned the common phone profile to one CIPC phone, but no luck. Still user have to select the image from settings, it is not getting reflecting automatically in CIPC background.
Highlighted
Highlighted
For 7945 it is working. Really appreciate your support on this.
Highlighted
No worries. Good to know that you got it working. I tried on CIPC and its
not working. I don't think CIPC gets the same TFTP parameters are desk
phones.
Highlighted
Please have a look on below bug.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCud67313/?rfs=iqvred
==Please rate all useful posts and mark as answer if it solves your issue==
Highlighted
Thanks, I am aware about this bug, looking for alternate solution.
Highlighted
Nithin, please refrain from posting images of the actual bug information and simply direct people to the bug via the URL, that information requires people to login in order to see it and you posting it like that bypasses such authentication mechanism.
java
if this helps, please rate
Highlighted
Noted and Removed the image.
Content for Community-Ad
