10-29-2015 12:20 PM - edited 03-17-2019 04:45 AM
CISCO IP Phone with SIP 7942 , 7962 , 7975 not showing VPN options under Security , SCCP is fine
We use IP SSL to connect to ASA but we cannot get the SIP phone to show the vpn options
Any ideas?
Checked SIP profile and templates , Common Phone Profile is setup to show VPN
Active Load ID: | SIP75.9-4-2-1S |
Active Load ID: |
SIP42.9-4-2-1S |
Solved! Go to Solution.
10-29-2015 03:31 PM
As per the following doc, VPN feature is available to ip phones running SCCP and not SIP.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/8_0/english/administration/guide/62adm80/62614241apxb.html#wp1019443
Carlo
10-29-2015 03:31 PM
Carlo
10-30-2015 07:20 AM
Thank you Carlo
Well that explains it .
Also i found the same document for the 7975 version , it is not supported via SIP , only SCCP
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_5/english/admin_guide/75adm80/7970dif.html
Thanks for your help
10-30-2015 07:23 AM
Yes Correct.
Glad to help and thanks for nice rating!
Carlo
