CISCO IP Phone with SIP 7942 , 7962 , 7971 not showing VPN options under Security , SCCP is fine
chrherr17
Beginner
Beginner
CISCO IP Phone with SIP 7942 , 7962 , 7975 not showing VPN options under Security  , SCCP is fine
We use IP SSL to connect to ASA but we cannot get the SIP phone to show the vpn options
Any ideas?
Checked SIP profile and templates , Common Phone Profile is setup to show VPN
Cisco Unified CM Administration
System version: 10.5.2.10000-5
Phone 7975
Active Load ID: SIP75.9-4-2-1S
Phone 7942G
Active Load ID:
SIP42.9-4-2-1S
As per the following doc, VPN feature is available to ip phones running SCCP and not SIP.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/8_0/english/administration/guide/62adm80/62614241apxb.html#wp1019443
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
Thank you Carlo
Well that explains it .
Also i found the same document for the 7975 version , it is not supported via SIP , only SCCP
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_5/english/admin_guide/75adm80/7970dif.html
Thanks for your help
Yes Correct.
Glad to help and thanks for nice rating!
Carlo
