12-30-2019 12:03 AM
Hi ,
My customer wants to have the following:
When client hold "#" on IP Phone pad the Phone automatically place a call to some number(without press "dial" just hold the button "#" for a few seconds).
Thanks.
12-30-2019 12:59 AM
12-30-2019 01:03 AM
The client want to hold "#" for emergency calls.
There is translation pattern configured on CUCM for "#" pattern which translate "#" to the Emergency number.
The client doesn't use "#" button for something else.
12-30-2019 04:33 AM
As Leo described below, you should consider creating a Speed-Dial, what type of Phone Device does your costumer use?
12-30-2019 07:34 AM
That cannot be done, if they're on hook, you need to press dial to place a call, just leaving a button pressed does nothing. If they're off hook, the translation pattern will do the job.
