Cisco IP phones not getting correct time
Hello cisco IP phone which is provisioned through CUCM gets incorrect time.
The time looks like adding 4 hours to standard time, for instance, our local time must be 18:00 PM but phones showing 18:00 + 4 hours.
2 Accepted Solutions
We contacted the TAC and they report us this is a BUG. Then they fixed it.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux50133/?rfs=iqvred
@George Sotiropoulos  no involved to upgrade but involved some server resource problem then CUCM pub and SUB get out of sync.
1. Our servers had resource problem and then NTP bug came.
2.IF NTP are not correct PUB and SUB got outof sync.
Solution:
  1. Login to Cisco Unified Reporting web page of CUCM Publisher, went to System Reports -> Unified CM Database Status and generated new report. Then checked the report to confirm that all configuration files are fine on both CUCM nodes and both of them can communicate to the DB of each other.
  2. Checked and confirmed that both nodes of CUCM cluster are authenticated by running “show network cluster” command.
  3. Stopped DB replication by running “utils dbreplication stop all” command on CUCM Publisher.
  4. Checked and confirmed that DB replication is stopped by running “utils dbreplication runtimestate” command.
  5. Checked and confirmed that the next services are running on both CUCM nodes:
  • A Cisco DB
  • A Cisco DB Replicator
  • Cisco Database Layer Monitor
  1. Reset DB replication by running “utils dbreplication reset all” command on CUCM Publisher.
  2. Monitored DB replication by running “utils dbreplication runtimestate” command every 15 min.
17 Replies 17
Jaime Valencia
Is the date time group the right one, have you tried changing it? Have you tried a different FW?
java
if this helps, please rate
Yes, time group is the right one. I tagged some pictures from CUCM.
On a specific phone, under Device Information you may change the "Device Mobility Mode" to "Off" and then press "Save" and "Reset" the phoneDevice Mobility Off.png
Let us know if this works for you,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
I changed "Device Mobility Mode"  to off and the restarted phone but again time is incorrect, it differs only 4 hours.
Alson from phone configuration menu I clicked "reset" and then "restart" but not affecting the phone. I restarted the phone manually.
I also tried to change the time group settins but not affecting phones.
From the OS Admistration Page, you may need to confirm that the NTP Settings and the Time of your CUCM is correct. Other than that, a good idea is to update the firmware on the phone(s) to avoid the possibility of "hitting" a bug.
George
I checked from the OS administration page for the NTP setting but its okay.
We have 4 model phones and all of then are incorrect time this should not be a bug.
I fixed the problem just restarting services in SUBscriber . Then phones got the correct time from PUblisher.
So the problem you can saw from pictures I tagged in our subscriber which does not have the correct time.
I tried to add NTP setting to SUB but not permitting me. How I provide Sub get syncretized from the pub ?
Subscribers get their time from the publisher.
Response Signature
@Roger Kallberg okay subscriber gets their time from the publisher. what can be a problem source for sub not getting NTP setting from the pub?
PUB ::::::
utils ntp status
ntpd (pid 27143) is running...
remote refid st t when poll reach delay offset jitter
*172.18.101.11 194.192.112.20 3 u 232 256 377 1.130 4.813 6.137
+172.18.101.12 172.18.101.11 4 u 219 256 377 1.017 -6.472 7.239
synchronised to NTP server (172.18.101.11) at stratum 4
time correct to within 173 ms
polling server every 256 s
Current time in UTC is : Sun Feb 9 17:20:43 UTC 2020
Current time in Asia/Baku is : Sun Feb 9 21:20:43 +04 2020
SUB::::
admin:utils ntp status
ntpd (pid 15767) is running...
No association ID's returned
unsynchronised
polling server every 8 s
Current time in UTC is : Sun Feb 9 21:20:23 UTC 2020
Current time in Asia/Baku is : Mon Feb 10 01:20:23 +04 2020
Restart NTP in the SUB, give it a few minutes and check status again.
java
@Jaime Valencia  I did it but no difference. Why UTC time is different in SUB?
Something is not correct with your subscriber. It should show the pub as the NTP server. See below from a system I've got access to.
SUB
ntpd (pid 2845) is running...
*10.192.31.5 10.192.4.210 2 u 340 1024 377 0.619 -0.161 0.070
synchronised to NTP server (10.192.31.5) at stratum 3
time correct to within 58 ms
polling server every 1024 s
Current time in UTC is : Mon Feb 10 11:46:14 UTC 2020
Current time in America/Chicago is : Mon Feb 10 05:46:14 CST 2020
PUB
ntpd (pid 1672) is running...
*10.192.4.210 .GNSS. 1 u 715 1024 377 0.219 -0.031 0.086
+10.67.1.250 .GNSS. 1 u 552 1024 377 127.645 -0.018 0.114
+10.138.1.12 .GNSS. 1 u 402 1024 377 216.269 -0.137 0.194
synchronised to NTP server (10.192.4.210) at stratum 2
time correct to within 26 ms
Current time in UTC is : Mon Feb 10 11:46:03 UTC 2020
Current time in America/Chicago is : Mon Feb 10 05:46:03 CST 2020
I would recommend you to verify that the CM nodes have communication with each other and that database replication is in a good state. Check these commands on all nodes.
  • show tech network hosts
  • show status
  • utils dbreplication runtimestate
  • show network cluster
  • utils diagnose test
  • utils core active list
And check in RTMT if there are any alerts.
Response Signature
