11-25-2014 07:17 AM - edited 03-17-2019 01:05 AM
Hello, is it possible to create internal phone number with live audio source for everyone to listen.
I have CME with VIC3-E/M card and CUCM 9.1. Audio signal coming to E & M voice port with disabled signaling, CME connected to CUCM via SIP trunk. And now users can call to special number, and listen audio translation. But POTS port has only one line and second user can't dial this number (line is busy).
Is there workaround of this issue with this software and hardware? Or what is the proper way to implement this?
11-25-2014 07:48 AM
I've been looking at these products recently... this PDF shows how you can use a little hardware box to stream multicast audio, and get the phones to receive it.
They're only a few hundred dollars...
http://www.barix.com/fileadmin/data/howto/Instreamer-Cisco_application_note_v14.pdf
Aaron
11-27-2014 12:30 AM
Hi, Aaron.
Thank you for info,
So why it couldn't do with Cisco hardware?
Cisco CME can send multicast with "feed ip 239.X.X.X" command, or I mistaking?
Only the question is write and host XML page, that can be parsed by IP Phone with commands to start and stop receiving RTP multicast, and subsribe phone to this page as a Phone Service.
I tried to create simple page, but have "HTTP content is not supported 23" error.
The hardware you described is using static XML file to provide service, can you show the XML file that generated by Barix Instreamer?
11-27-2014 01:31 AM
As I say, i don't have one yet.
The arguments against using Cisco kit would be expense, messy cabling, complexity etc. A little one-box device that streams continually and serves only that purpose seems like a good idea to me.
Maybe post up your code. I don't have an instreamer to get the pages from, but can review what you have written.
Aaron
11-27-2014 02:20 AM
The code is:
11-27-2014 02:31 AM
Your menu fragment is OK.
What web server are you using?
Basically the server needs to set the 'content-type' header to text/xml for the phone to parse it. IIS does this based on the file extension, so if you have called it html or something, call it .xml. If you are using another web server it might need more config.
Are you using the IOS web server?
Aaron
11-27-2014 03:14 AM
Thank you,
For test i used Synology WEB station, linux apache WEB-server. And i weak in web-developing.
Can IOS web server serve content in needed "content-type"? It can will be great one-box solution.
11-28-2014 07:44 AM
I googled it, and it claims to support content-type as a valid option (http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/https/configuration/12-2sy/https-12-2sy-book/nm-http-web.html)... however I don't see how you configure it if it's not based on the file extension.
Did you have the file named whatever.xml?
If so I'd probably get the CME GUI files on their and see how they work, they'll definitely serve up XML to the phones...
Aaron
12-02-2014 03:49 AM
Hi, Thank You, for the info Aaron.
I configured endpoints, but hear nothing.
Phone executing command from XML, sends IGMP reports to join group to network, CME sends rtp flow to network.
A tried to forward packets from CME to IP-phone for a last week, but not succesful.
I notice that a not so much documentation about enabling multicast in C3750 L2 network, and most configurations has a router.
Please, could you tell about simple enabling multicast and in VLAN on C3750?
CME in a same LAN with IP Phones, default router in the network is L3/2 switch stack.
What route might be written in "feed ip" command on CME(Multicast-Server), is it needed to enable "ip multicast-routing" on switches?
Perfectly will be a bare minimum of config to enable Multicast forwarding throuhg the switches.
(CME(multicast server))-(L3/2-Core-Switch)-(L3/2-Gateway-Switch-Stack(With Users))
Please help, if You can, i'll provide needed information.
12-02-2014 05:53 AM
Can you post your CME config?
And your 3750?
If you do a show int on the switch for the CME port do you see it receiving mcast packets?
Generally if the sender and worry about mcasteh same VLAN you don't need to worry about mcast much as it's not being routed. IIRC IGMP snooping is on by default.
Aaron
12-03-2014 02:25 AM
Hi!
Thank you.
Here is config of CME (It also used for internet connection)
CME#sh run Building configuration... Current configuration : 8035 bytes hostname CME ! voice-card 0 ! ! ! voice service voip ip address trusted list ipv4 172.16.60.0 255.255.254.0 allow-connections h323 to h323 allow-connections sip to sip no supplementary-service sip moved-temporarily fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none h323 sip registrar server expires max 3600 min 3600 ! voice class codec 1 codec preference 1 g711ulaw ! voice class h323 1 h225 timeout tcp establish 3 h225 timeout setup 3 ! ! license udi pid CISCO2901/K9 sn FCZ1609C2SZ hw-module pvdm 0/0 ! username XXXX privilege 15 secret 5 XXXX ! redundancy ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 description Uplink ip address XXXXXXXX ip access-group 101 in ip nat outside ip virtual-reassembly in duplex auto speed auto no cdp enable ! interface GigabitEthernet0/1 description Link to LAN ip address XXXXX ip access-group 100 in ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/1.30 description VOIP encapsulation dot1Q 30 ip address 172.16.60.20 255.255.254.0 h323-gateway voip interface h323-gateway voip bind srcaddr 172.16.60.20 ! ! ip forward-protocol nd ! ip http server ip http authentication local no ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! {NAT and ACL rules} ! control-plane ! voice-port 0/0/0 - Live Source auto-cut-through operation 4-wire signal immediate input gain 14 ! voice-port 0/0/1 ! mgcp profile default ! ! dial-peer voice 500 pots destination-pattern 3000 port 0/0/0 ! ! dial-peer voice 1 voip description Incoming for test live source session protocol sipv2 session target sip-server incoming called-number .% dtmf-relay rtp-nte no vad ! ! sip-ua sip-server ipv4:172.16.60.20 ! ! gatekeeper shutdown ! ! telephony-service max-ephones 10 max-dn 10 ip source-address 172.16.60.20 port 2000 max-conferences 8 gain -6 transfer-system full-consult create cnf-files version-stamp ! ! ephone-dn 1 number 3000 ! ! ephone-dn 2 dual-line number 3001 ! ! ephone-dn 3 number 3003 feed ip 239.0.0.10 port 20480 route 172.16.60.6 (Nighbour switch SVI) out-call 3000 ! ! ephone 2 (Phone for testing live source) mac-address 10BF.4867.E608 type CIPC button 1:2 ! ! ! line con 0 login local line aux 0 line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 logging synchronous login local transport input telnet ssh line vty 5 15 logging synchronous login local transport input telnet ssh ! scheduler allocate 20000 1000 end
Port of the switch next to CME is receiving mcast packets. Counter is increasing so fast (about 100 packets/sec)
12-03-2014 03:54 AM
I think the 'route' param in your feed ip command should be set to the source address to use, e.g. 172.16.60.20, rather than the next hop.
Aaron
12-03-2014 04:59 AM
Changed the param, not worked,
Mcast packet is received too.
How can i trace the multicast traffic through the network?
Can initiate synthetic join to multicast group on switches for troubleshoot?
12-03-2014 08:39 AM
You can put 'ip igmp join-group x.x.x.x' on an interface.
You'd first need to enable IGMP - put 'ip pim dense' on the interface facing the router. That enables PIM, but also IGMP on the interface.
Also verify you have IGMP snooping on the 3750. It's on by default.
Aaron
12-03-2014 11:58 PM
Hi, Aaron, and thanks.
First of all, i put "ip igmp join-group X.X.X.X" on interface Vlan 30, on switch neighbour to CME (172.16.60.6), and second switch (with users) (172.16.60.1).
I used Vlan int cause there is Trunk between CME and CoreSW. Correct me if this is not right. Must i use Sub-Interface?
Then i put "ip pim dense" on interface Vlan 30 switch neighbour to CME (CoreSW), and saw "Warning" about multicast routing.
Then i exec "sh ip igmp groups" on switches:
CoreSW:
Group Address Interface Uptime Expires Last Reporter 239.0.0.10 Vlan30 18:14:36 00:02:27 172.16.60.6224.0.1.40 Vlan30 01:23:34 00:02:30 172.16.60.9
UserSW:
Group Address Interface Uptime Expires Last Reporter Group Accounted 239.0.0.10 Vlan30 1d21h stopped 172.16.60.1
There are no multicast packet between CoreSW and UserSW
IGMP snooping enabled on both switches.
Debug IP IGMP groups on CoreSW:
007309: 3d23h: IGMP(0): Received v2 Report on Vlan30 from 172.16.60.6 for 224.0.1.40 007310: 3d23h: IGMP(0): Received Group record for group 224.0.1.40, mode 2 from 172.16.60.6 for 0 sources 007311: 3d23h: IGMP(0): Updating EXCLUDE group timer for 224.0.1.40 007312: 3d23h: IGMP(0): Received v2 Report on Vlan30 from 172.16.60.1 for 239.0.0.10 007313: 3d23h: IGMP(0): Received Group record for group 239.0.0.10, mode 2 from 172.16.60.1 for 0 sources 007314: 3d23h: IGMP(0): Cancel report for 239.0.0.10 on Vlan30 007315: 3d23h: IGMP(0): Updating EXCLUDE group timer for 239.0.0.10 007316: 3d23h: IGMP(0): Received Leave from 172.16.60.1 (Vlan30) for 224.0.1.40
Debug IGMP Snooping on CoreSW:
007230: 3d22h: IGMPSN: group: Received V2 report for group 239.0.0.10 received on Vlan 30, port Gi1/0/12 007231: 3d22h: IGMPSN: group: Adding client ip 172.16.60.1, port_id Gi1/0/12, on vlan 30 007232: 3d22h: IGMPSN: group: Added port Gi1/0/12 to group 239.0.0.10 007233: 3d22h: IGMPSN: group: Forwarding 239.0.0.10 report to router ports 007234: 3d22h: IGMPSN: timer: Vlan 30 report timer expired 007235: 3d22h: IGMPSN: Received SVI query(224.0.0.1) on vlan 30 007236: 3d22h: IGMPSN: Adding iquerier flag in vlan 30 007237: 3d22h: IGMPSN: router: iquerier added on Vlan 30 007238: 3d22h: IGMPSN: group: Received V2 report for group 239.0.0.10 received on Vlan 30, port Gi1/0/12 007239: 3d22h: IGMPSN: group: Added port Gi1/0/12 to group 239.0.0.10 007240: 3d22h: IGMPSN: group: Forwarding 239.0.0.10 report to router ports 007241: 3d22h: IGMPSN: timer: Vlan 30 report timer expired 007242: 3d22h: IGMPSN: group: Leave for group 239.0.0.10 received on Vlan 30, port Gi1/0/12 007243: 3d22h: IGMPSN: group: Adding client ip 172.16.60.5, port_id Gi1/0/12, on vlan 30 007244: 3d22h: IGMPSN: group: Created v2 leave port on port Gi1/0/12, for group 239.0.0.10 on Vlan 30 007245: 3d22h: IGMPSN: group: Sending Group-Specific Query for group 239.0.0.10 on Vlan 30, port Gi1/0/12 007246: 3d22h: IGMPSN: timer: Vlan 30, group 239.0.0.10, port Gi1/0/12 leave port timer expired 007247: 3d22h: IGMPSN: group: Deleting leave port on port Gi1/0/12, for 239.0.0.10 on Vlan 30 007248: 3d22h: IGMPSN: mgt: deleted port Gi1/0/12 on gce 0100.5e00.000a, on Vlan 30 007249: 3d22h: IGMPSN: group: Deleting port Gi1/0/12 from group 239.0.0.10 on Vlan 30 007250: 3d22h: IGMPSN: group: Deleting group 239.0.0.10 007251: 3d22h: IGMPSN: mgt: deleting group EF00000A, on Vlan 30 007252: 3d22h: IGMPSN: group: Deleting gce 0100.5e00.000a 007253: 3d22h: IGMPSN: mgt: deleting gce 0100.5e00.000a, on Vlan 30 007254: 3d22h: IGMPSN: group: Sending Leave for group 239.0.0.10, source 172.16.60.5 on Vlan 30 007255: 3d22h: IGMPSN: Received SVI query(239.0.0.10) on vlan 30 007256: 3d22h: IGMPSN: Adding iquerier flag in vlan 30 007257: 3d22h: IGMPSN: router: iquerier added on Vlan 30 007258: 3d22h: IGMPSN: group: Received V2 report for group 239.0.0.10 received on Vlan 30, port Gi1/0/4 007259: 3d22h: IGMPSN: group: Adding client ip 172.16.60.9, port_id Gi1/0/4, on vlan 30 007260: 3d22h: IGMPSN: mgt: created gce 0100.5e00.000a, on Vlan 30 007261: 3d22h: IGMPSN: mgt: created group EF00000A, on Vlan 30 007262: 3d22h: IGMPSN: group: Created group 239.0.0.10 007263: 3d22h: IGMPSN: mgt: added port Gi1/0/4 on gce 0100.5e00.000a, Vlan 30 007264: 3d22h: IGMPSN: group: Added port Gi1/0/4 to group 239.0.0.10 007265: 3d22h: IGMPSN: group: Forwarding 239.0.0.10 report to router ports 007266: 3d22h: IGMPSN: group: Received V2 report for group 239.0.0.10 received on Vlan 30, port Gi1/0/12 007267: 3d22h: IGMPSN: group: Adding client ip 172.16.60.1, port_id Gi1/0/12, on vlan 30 007268: 3d22h: IGMPSN: mgt: added port Gi1/0/12 on gce 0100.5e00.000a, Vlan 30 007269: 3d22h: IGMPSN: group: Added port Gi1/0/12 to group 239.0.0.10
Debug IGMP on UserSW:
*Mar 4 22:49:44.568: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:49:44.568: IGMP(1): Set report delay time to 3.5 seconds for 239.0.0.10 on Vlan30 *Mar 4 22:49:48.158: IGMP(1): Send v2 Report for 239.0.0.10 on Vlan30 *Mar 4 22:49:54.567: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:49:54.567: IGMP(1): Set report delay time to 7.6 seconds for 239.0.0.10 on Vlan30 *Mar 4 22:49:55.574: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:50:02.184: IGMP(1): Send v2 Report for 239.0.0.10 on Vlan30 *Mar 4 22:50:44.899: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:50:44.899: IGMP(1): Set report delay time to 0.8 seconds for 239.0.0.10 on Vlan30 *Mar 4 22:50:45.754: IGMP(1): Send v2 Report for 239.0.0.10 on Vlan30 *Mar 4 22:51:45.305: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:51:45.305: IGMP(1): Set report delay time to 1.6 seconds for 239.0.0.10 on Vlan30 *Mar 4 22:51:46.312: IGMP(1): Received v2 Report on Vlan30 from 172.16.60.6 for 239.0.0.10 *Mar 4 22:51:46.312: IGMP(1): Received Group record for group 239.0.0.10, mode 2 from 172.16.60.6 for 0 sources *Mar 4 22:51:46.312: IGMP(1): Cancel report for 239.0.0.10 on Vlan30 *Mar 4 22:52:45.627: IGMP(1): Received v2 Query on Vlan30 from 172.16.60.6 *Mar 4 22:52:45.627: IGMP(1): Set report delay time to 2.7 seconds for 239.0.0.10 on Vlan30
Debug igmp snooping on UserSW:
*Mar 4 23:01:48.974: IGMPQR: vlan_id 30: GQ with src addr 172.16.60.6 received on port Gi1/0/1 in Disabled state *Mar 4 23:02:49.372: IGMPQR: vlan_id 30: GQ with src addr 172.16.60.6 received on port Gi1/0/1 in Disabled state *Mar 4 23:03:49.770: IGMPQR: vlan_id 30: GQ with src addr 172.16.60.6 received on port Gi1/0/1 in Disabled stateu all
Is this is normal functioning of IGMP? Thanks
