Beginner
Cisco IP Voice Media Streaming App
I just built a new 10.5 cluster.  In this cluster I have a publisher and a single subscriber.  If I use the CM Group that has only the publisher, or at least the publisher first, the annunciator and software conference bridge register fine.  If I change them to the CM Group where the subscriber is listed first then they remain unregistered.  I have checked and both servers are running the Cisco IP Voice Media Streaming App service.
This is the same configuration I am using on my 8.6.2 clusters, which are working.
5 REPLIES 5
You can try restarting the
You can try restarting the IPVMSA service on the subscriber first. If the media resources are still unregistered you can collect the detailed IPVMSA traces and they can be looked at for any errors related to these media resources.
Manish
Highlighted
Beginner
I have tried restarting the
I have tried restarting the service and have even gone as far as to reboot the whole server.  No luck.
How do I get the detailed traces?
You need to check the trace
You need to check the trace debug level from Cisco Unified serviceability > Trace configuration and collect it from RTMT after a restart of IPVMSA service
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/10124-cm-trace.html
Manish
Beginner
Hi Manish, Okay, so I have
Hi Manish,
Okay, so I have logged into the subscriber CM and I see the annunciators are registered there.  However, when I log back into the publisher, it still shows Unregistered.  Looks like I am having Db sync issues.  I'm going to open a TAC case.   Thanks for your help.
Beginner
I just found another post
I just found another post with the same problem and they reset the Cisco RIS Data Collector service to fix the problem.  This worked for me too.
Content for Community-Ad
August's Community Spotlight Awards
