Highlighted
Beginner
cisco ipphone 9951 reset
Good mornig, I've a problem with one 9951 ipphone.
It won't regiater on my cucm 8.6, and  I dont have found a method to reset it to defalut factory,
Can you help me?
Thanks in advance
Giancarlo
7 REPLIES 7
Highlighted
Is this a new phone? What errors do you see in the status messages?
To factory reset the phone:
From the Administrator Settings menu, unlock phone options, then choose Reset Settings > All Settings
Highlighted
Beginner
Re: cisco ipphone 9951 reset
Hi, I've loaded factory defalut, bur the phone won't register.
in the status  I see the following messages (always the same)
Aggiornamento trust list
Trust list aggiornata
SEPFCFBFB111DF1.cnf.xml
Highlighted
I don't know what language that is, but it looks like the phone cannot download its configuration file from CUCM. Is the TFTP server address set to the CUCM TFTP server? Is the phone configured in CUCM?
Highlighted
Beginner
the language is italian,
the tftp server address is configured on phone and the phone is configured on cucm
Highlighted
Beginner
I think that the problem is the firmware version.
Actually on the phone is loaded the 9.0.3
The CUCM 8.6 Has a 9.2.1.
I think that is necessary load an intermediate release (like 9.1.1)
But the problem is that I don't have access to download it.Can you have this release?
Thanks in advance
Giancarlo
Highlighted
Frequent Contributor
you need to do
2911POS(config)#voice register global
2911POS(config-register-global)#create profile
and phone will register
Highlighted
It's a CUCM, not a CME
@ gevangelista: you should ask your Cisco partner for download permissions on Cisco.com.
