Beginner
Cisco ISM-SRE-300-K9
Hello, I am trying to decide which is better to use, I have a cisco 2921 router that has a PVDM3-32, My IOS is 15.7M and I wanted to know which would be better the PVDM3 or ISM-SRE-300-K9 module? I also have CME 12.0.
This will also be using Unity for voicemail.
3 REPLIES 3
Hall of Fame Cisco Employee
Re: Cisco ISM-SRE-300-K9
You are asking about things that are used for completely different things, which one you need, depends on your requirements.
If you want CUE, then you need the SRE, if you meant CUC, then you would not need the SRE
java
if this helps, please rate
Beginner
I would like to know was which would be better since I have CME 12.0. The ISM module which I will purchase? or the PVDM3 which is already installed with the router which is using IOS 15.7M and also which version of Cisco Unity would work for this possible setup?  I already have a SIP setup from my vendor, Just trying to decide which route to go.
Highlighted
Again, you are asking a comparison of things that have a completely different use. Which one is better??? depends on what YOU want/need.
I would strongly suggest you reach out to a reputable consultant or a local Cisco partner with UC specializations for assistance.
java
Content for Community-Ad
July's Community Spotlight Awards
