Community Helping Community
2886
Beginner
Cisco ISR 4321 cannot download MGCP XML Configuration Files
Dear all,
I'm trying to configure Cisco ISR 4321 as MGCP gateway. I've configured the hostname and domain name in MGCP gateway. And i've added the MGCP gateway using device name : hostname.domain name. In the MGCP gateway, i've entered two commands :
ccm-manager config
ccm-manager config server (ip address of CUCM)
I've verified network connectivity between MGCP gateway and CUCM, it's ok. The MGCP gateway and CUCM is located in the same network segment, no firewall between them. But the MGCP gateway cannot download the configuration file from CUCM. Does anyone have any idea?
Thank you.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Collaborator
Check your config for the
Check your config for the command "ip tftp source-interface" and make sure it references the correct interface. My came out of the factory referencing GigabitEthernet0 which is the management interface, not one of the main interfaces.
I general had huge problems recently setting up a new 4321 router for MGCP. The IOS for this range appears to be quite flaky for voice. I'm using sr4300-universalk9.03.15.02.S.155-2.S2-std.SPA.bin as my firmware image as this was the one that seemed to work.
GTG
Please rate all helpful posts.
10 REPLIES 10
Engager
I personally don't like these
I personally don't like these two commands as it downloads many other configuration which I need to change later on manually. Do you see it's mandatory for you to configure gateway like this?
- Vivek
Hi.
Hi.
Can you share a debug ccm-manager config-download?
To retrieve the output first issue no ccm-manager config and ccm-manager config again in config mode
Carlo
Please rate all helpful posts "The more you help the more you learn"
Rising star
More over I am bit surprised
More over I am bit surprised the need or the requirement to use MGCP gateway. I would be more happy to go H323 or even better SIP Gateway (aka CUBE) than an MGCP.  However sometimes, we need to use the older technology :)
Collaborator
GTG
Beginner
Re: Check your config for the
This was happening to me as well. Mine came default "ip tftp source-interface GigabitEthernet0" and I had to change it to "ip tftp source-interface GigabitEthernet 0/0/0"for it to work for my MGCP registration. Thank you for this.
Bryan,
Bryan,
can you please add this command on GW and do no ccm-manager config and ccm-manager config.
#ip tftp source interface < interface>===this is should be same as mgcp bind command pointed to that interface.
also check bind command is there or not if not added the same
#mgcp bind control source-interface <interface>
#mgcp bind media source-interface <interface>
Br,
Nadeem
PS; Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hall of Fame Community Legend
Hi Bryan,
Hi Bryan,
In addition to the good tips from my friends Vivek, Carlo, Gordon & Nadeem (+5 each!)
This bug is interesting as well;
43xx/44xx removes Mgcp bind on reboot
CSCuv85943
Thanks Rob my friend (+5) for
Thanks Rob my friend (+5) for sharing the BUG.
Br,
nadeem
+5 Rob,
+5 Rob,
Great as usual my friend ;)
Cheers
Carlo
Contributor
100% correct on this.  The
100% correct on this.  The newer ISR come with the wrong default for ip tftp.  Especially is you use Loopback1 as your registration point.  A show run command does not expose this.  Thanks for great info.
Content for Community-Ad
FusionCharts will render here
