12-09-2015 01:28 PM - edited 03-17-2019 05:10 AM
HI,
Have bought a couple of ISR4331's to replace some EOL 2800 series routers. We have found some quirks or changes in standard voice commands for E1 interfaces but we have not been able to find a Gatekeeper command anywhere. Does anyone know how we can access this level of commands?
Cheers
Dave
Solved! Go to Solution.
12-10-2015 01:28 AM
The 44xx series routers don't have gatekeeper functionality. I found that out the hard way too :-(
It's buried in some docs on cisco.com somewhere.
GTG
12-09-2015 01:45 PM
can you please post show license feature command from the router.
Gatekeeper(gatekeeper) feature license can be enabled only when have uck9 technology package license enabled.
Br,
Nadeem
PS: Please rate all useful post.
12-09-2015 02:22 PM
Hi Nadeem,
I will check tomorrow morning for this. We did purchase the router with the following licenses:
SL-4330-UC-K9 - Unified Communication License for Cisco ISR 4330 Series
I'm guessing I need to activate this before I will get the commands. WIll update and let you know.
Cheers
Dave
12-09-2015 02:39 PM
alright just keep me posted let see how it goes.
Br,
Nadeem
12-10-2015 12:52 AM
UC license is enabled:
Index 2 Feature: uck9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
bootflash:/isr4300-universalk9.03.13.02.S.154-3.S2-ext.SPA
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx None None None
uc uck9 Permanent uck9
security None None None
ipbase ipbasek9 Permanent ipbasek9
I still can't get to the gatekeeper commands. Any ideas?
Cheers
Dave
12-10-2015 01:19 AM
Hi Dave,
Was a reload of the router done after installing the license file
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#pgfId-1097551
Manish
12-10-2015 01:22 AM
Thanks for the response.
The UCk9 license was installed on the router when we got it so we have rebooted multiple times. I don't need to run through a license activation again do I? Is it an IOS issue? I'm struggling to find any supporting documentation.
Dave
12-10-2015 01:28 AM
GTG
12-10-2015 01:31 AM
Hi Gordon,
Ouch! That could be a painful and expensive issue. Is that across all ISR4000 routers or just the 44xx series? (clutching at straws).
Cheers
Dave
12-10-2015 01:33 AM
I think it's the entire range. I found this out when I looked for the commands on my 4321.
GTG
12-10-2015 01:35 AM
Thanks Gordon,
I don't suppose you know where that documentation lies? I need to inform the customer and put a plan into action....
Cheers
Dave
12-10-2015 01:46 AM
I was just doing a quick google and couldn't find the document that says that, sorry.
GTG
12-10-2015 02:10 AM
Thanks Gordon for pointing that out [+5] , just checked the IOS Gatekeeper guide and found the following
http://www.cisco.com/c/en/us/products/collateral/unified-communications/gatekeeper-multimedia-conference-manager/data_sheet_c78_561921.html
Feature Availability
• Cisco 3900 Series platforms (Cisco 3925 and 3945 platforms)
• Cisco 2900 Series Integrated Services Routers (Cisco 2901, 2911, 2921, and 2951 platforms)
• Cisco 3800 Series Integrated Services Routers (Cisco 3825 and 3845 Integrated Services Routers)
• Cisco 2800 Series Integrated Services Routers (Cisco 2801, 2811, 2821, and 2851 Integrated Services Routers)
• Cisco AS5400XM and AS5350XM Universal Gateways
• Cisco 7301 Router
• Cisco 7200VXR Series Routers
• Cisco 2600 Series Multiservice Platforms (Cisco 2610XM , 2611XM, 2620XM, 2621XM, 2650XM, and 2651XM Multiservice Routers and the Cisco 2691 Multiservice Platform)
• Cisco 3700 Series Multiservice Access Routers (Cisco 3725 and 3745 Multiservice Access Routers)
Looking at the 4000 series datasheet and config guides as well does not show any gatekeeper reference.
It would be a good idea though to engage your Cisco Account team and see if this is on the roadmap.
Manish
12-10-2015 02:23 AM
The problem with many of these docs on Cisco.com, is that Cisco don't go back and update them when new products are launched. So you can't always be 100% sure the document is true.
e.g. The datasheets for some of the 4000 series modules don't list the 43XX as supported devices. Yet the 4321 does list the module as supported. This is because the modules came out before the 43XX series existed and no-one thought to complete the loop and update the module docs when the 43xx series came out.
GTG
12-10-2015 10:55 AM
Thanks Gordon (+5) for cracking this oen, even i was under the impression but when checking internally feature tool yes ISR4331 not supported with this feature(Gatekeeper). Yes i understand the document needs to be updated .
Br,
Nadeem Ahmed
