Cisco jabber 12.9.1 configuration
iptsupport
Level 4
Level 4
hey everyone,
which values i need to change in Cisco jabber (installation file) to get this things:
1) i want that by default, when i install Cisco jabber to customer the option of  " start Cisco jabber when my computer is start " is be marked.
2) Cisco jabber be always in English, and not check my system Language.
3) Change the size screen of Cisco jabber.
Jaime Valencia
1) you can do that via the jabber-config.xml, refer to parameter guide.
2) you can use install switches or ORCA to create an installer with that option, covered in Jabber installation chapter
3) not possible
java
if this helps, please rate
Hey Jaime,
first i would like to thank you for your help.
where i can find the "parameter guide" ?
Did you even spend one minute of your own time before you asked that question? There is this thing named Google, it's very helpful for things like this. If you enter what Java wrote to you would find what you need.
Response Signature
