05-07-2014 02:29 AM - edited 03-16-2019 10:42 PM
We have a presence cluster System version: 8.6.5.10000-12.We have two server configured under the DefaultCUPSubcluster in high availability mode. All Contacts are searchable from Jabber, But when trying to add the contacts, we are unable to add the users who are assigned to the second server.
Eg, Server A has 50 Users assigned to it, and server B has 10, any user in Server A can add any of the assigned 50 users in the server A, but cannot add the 10 users in assigned in Server B. On trying to add, we get the following message " The system cannot currently add the contacts. Try again later or contact your system administrator"
Anyone face similar issue?
05-14-2014 11:06 PM
...exact same problem here... but we're running cupx 9.1... did you solv the problem?
05-17-2014 01:28 PM
same issue on 10.x. Secondly I can call the contact (without adding) but cannot IM either. No presence status either.
also in HA and when i do a manual failover I am able to add the contact and IM.
06-18-2014 08:32 AM
I had the same problem in a CUPS 9.1.1.30000-3 in a cluster With HA available, but I cant Add contacts to my jabber, I can Find them but I can`t add them to my jabber, also can call all users,
I make a probe and I assing the users that was failling to the Publisher Presence I that resolve the Issue but I cant figure it out wy in the subscriber is not function.
06-18-2014 12:30 PM
Under System->Cluster Topology->Settings, check that you have the Routing Communication Type set to Router to Router instead of Multicast DNS. This is what usually causes the inter-node communication problems. Changing it to Router to Router will need services reset.
07-03-2014 02:54 PM
Thank you very much It Works!
07-03-2014 02:56 PM
Great news! Make sure to mark the thread as resolved!
