07-03-2015 05:42 AM - edited 03-17-2019 03:31 AM
I have to deploy Cisco Jabber, but he doesn't start on OS start.
You could check the option in 'File' --> 'Options', or add the option 'Start_on_OS_Start' in the xml file.
I would modify the behaviour automatically.
Is there a registry key in windows that could be modified so that Jabber starts automatically ?
Thanks for help
Solved! Go to Solution.
07-06-2015 09:33 AM
Pre Jabber 10.5, you will be find jabber-config.xml in the path C:\Users\xxx\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config. The settings will be in jabber-config.xml.
Starting from Jabber 10.5, the settings will be located in the file cachedTFTPConfigStore.xml which is stored in C:\Users\xxxx\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config\Cache
07-03-2015 09:25 AM
The best way is to change this on jabber-config.xml as you mentioned. Upload the file to CUCM and restart TFTP service.
This will make each phone registering with CUCM/IMP to get this file with the settings you prefer.
07-06-2015 07:04 AM
Thanks Mohammed.
I've just to find out the correct format of the xml file.
Are the settings added to JabberLocalConfig.xml file located in the Users\...\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config folder ?
07-06-2015 09:33 AM
07-07-2015 12:52 AM
After changing the file located in \Users\xxxx\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config\Cache, could I upload it to the TFTP server on the CUCM ?
