04-27-2013 10:07 AM - edited 03-16-2019 05:02 PM
Dear All,
We have CUCM 8.6 and CUPS 8.6.We installed cisco Jabber for window.Its fail to login "Login failed - due to registration faliure".
CUCM is configurered but LDAP Authentication is not configured.
Is it important to configur LDAP Authentication for cisco jabber?
Regars,
Solved! Go to Solution.
04-28-2013 01:15 PM
Hello
Kindly find the below
https://supportforums.cisco.com/docs/DOC-24456
for the link also
kindly do not forget to rate all useful posts
thank you
please rate if this will help
04-27-2013 10:40 AM
Hi Waqas
Yes You can If you are on CM8.6.2 you can use UDS rather then LDAP, which means that it uses the CUCM directory.
you can find the below link
https://supportforums.cisco.com/thread/2163374
please answer the below questions
1- Which version of your Cisco jabber and your windows operating system?.
2-In your login you use the IP of your presence , or you use name of your CUP?
3-Did you configure DNS ?. If yes , you added the query of domain name of your CUP to the hosts file in your windows
C:\Windows\System32\drivers\etc\hosts.
I hope to get the below link
Thank you
04-28-2013 07:34 AM
Thanks for replay .It was domain issue that is solved .
Now i want to enable desktop sharring on cisco jabber.Can you please send me the link to download the cop file "cmterm-bfcp-e.8-6-2.cop.sgn"
04-28-2013 01:15 PM
Hello
for the link also
thank you
04-29-2013 09:09 AM
I download the "CiscoJabber-Admin-ffr.9-2-0" and extract .its include the cop files
