10-12-2012
09:08 AM
- last edited on
03-25-2019
08:18 PM
by
ciscomoderator
Hi Everyone,
Can anyone provide the step by step help for cisco jabber for windows configuration , i am currently having CUCM 8.6.2
and CUPS 8.6.4 and have already tried to configure it via the help of various video tutorial and also via Set UP 8.6 On-Premises Environment
but not able to make it working, if any one can help me for this that will be really appreciated.
Ali.
10-12-2012 09:09 AM
Hello the in configuration CUCM/CUPS is similar to CUPC 8.X
Look here:
These are the steps:
Creating a Softphone Device for Each Cisco Unified Personal Communicator User
Associating Users with Softphone Devices
Associating a New Device with a User
Rate this if helps!
Leonardo Santana
10-12-2012 09:22 AM
Hi Leonardo,
Thanks for replying so quick, i have already made the configuration in the same pattern with
i cant make calls from jabber client 9.0.5 intergrated with CUPS 8.6.4.
When i click a contact it allow me to chat only and i dont see a call button.
Also to add a contact i need to send a IM first, the contact serch option not showing other users.
10-12-2012 09:25 AM
The user is associate with the device?
You use Extension Mobility?
10-12-2012 09:28 AM
Yes i have created 4 users and all of them are associated with 4 different Phones,
I am currently not using the Extesion Mobility.
10-12-2012 09:31 AM
Hello did you make all these configs?
https://supportforums.cisco.com/docs/DOC-22103
Each user are associated with the correct device?
The directory number is associated with the end user?
The end user is associated with te correct user groups?
10-12-2012 09:35 AM
i will just go through this link and will double check my config steps with this
and will let you know soon later today, thanks once again for your prompt replies.
Ali.
