Cisco Jabber not registering with CUCM. "Untrusted server, No services discovered"
sy349@njit.edu
The CUCM was configured to register with the Jabber Endpoint for phone services. However I see that when I try to login to the application, The Jabber app shows an error saying "Untrusted server. No services discovered." I have the certificates installed on the Windows platform where the Jabber is installed. I also checked the IM&P services were working fine and I was able to send messages between endpoints. However, the app displays an error saying "Connection to phone service failed". I have attached the Jabber logs. Thanks in advance.
George Sotiropoulos
Have you tried to manually enter the setting on Jabber, for example denote manually that it is going to register on CUCM and enter the IP address of CUCM?
Hope the above helps,
gsotirop
