05-26-2025 05:08 PM - edited 05-27-2025 03:15 AM
I upgrade my publisher and subscriber from 11.5 to 15 then after upgrade successful i got this error when open the CCX.
When i try to resync the JTAPI i got this error
Actually the AXL service was running in the publisher
Solved! Go to Solution.
05-27-2025 12:48 AM
AFAIK that version isn’t compatible with CM 15. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/Unified_CCX_Software_Compatibility_Matrix_for_1251_SU3.html
You need CCX 12.5.1 SU3 ES04 or newer.
05-26-2025 09:23 PM
Can you please provide the exact version of CCX that you’re using?
05-26-2025 11:42 PM
05-27-2025 12:48 AM
