11-16-2013 08:49 AM - edited 03-16-2019 08:26 PM
Hi all
I get an error on my CUCM administration console , i have CUCM v9.1 VMware . Any one get an error like the attached .
11-16-2013 12:57 PM
You get that if you havent configured the product in ELM and/or you dont have the proper licensing.
Do you have the above??
It seems you just finished the install and have not done the ELM part.
11-16-2013 06:35 PM
Hi Kamel,
From the snapshot,it seems that licenses have not been installed and is working on Demo period.
you can check the same by logging into ELM, license management---licenses.You shall find status as DEMO else it should be Permanent/In Compliance.
regds,
aman
11-16-2013 11:37 PM
Dear All
I have already uploaded licenses for ELM . This problem ,happens after register my IPHONE and SAMSNG as jabber.
11-16-2013 11:39 PM
hi,
Can u share the snapshot of licenses from ELM?
regds,
aman
11-17-2013 12:09 AM
11-17-2013 12:29 AM
Hi Kamel,
from the snapshot,I can see In Compliance and do not see any Insufficient licenses message.This may due to Licenses which have been borrowed from Enhanced Plus UCL[6 qty.] and alloted to Jabber Clients under Enhanced UCL
regds,
aman
11-17-2013 12:37 AM
HI Aman
Yes , no errors my friend bec all jabber now unregistered.My question as you see, i have to purchase Jabber license? and which type of licenses for iphone and samsung?.
11-17-2013 01:07 AM
Hi KAmel,
If Jabber is not configured as a CSF, then, u require ENH license.
you can refer the ordering guide
regds,
aman
