Highlighted
Beginner
Cisco MediaSense with c7940 ip phone
Dear Sir,
I have CUCM and  cisco mediasense server 11.x. I am using a lot of Cisco 7940 IP phones in our network and try to record the cisco IP phone 7940 phone calls. But I am not able to record the 7940 ip phone in mediasense server because C7940 don't have the Build-in-bridge features. Is there the solution to record 7940 ip phone calls in mediasense. Could you please advise.
Thank you.
Best Regards,
Vector
Is it possible to use "SPAN-based Solution" in mediasense...
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab09/clb09/recordng.html
4 REPLIES 4
Highlighted
Hi Vector,
Yes, SPAN based recording solution would work, one of the main considerations being the bandwidth utilization.
You can also use Network based recording on CUBE but it works for SIP-SIP calls only details here
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_proto/configuration/15-mt/cube-proto-15-mt-book/voi-ntwk-based.html
Manish
Highlighted
Will the CUBE based recording work for Internal IP Phone to IP Phone Calls ?
Or Does it need the call to be passed via SIP Trunk ?
Haris
Highlighted
Hi Haris,
WIth Gateway Preferred Network based recording enabled and BiB disabled on the phone the internal calls should not be recorded.
Manish
Highlighted
Hi Manish,
Thank you for your reply, but we are trying to record internal calls(C7940 IP phones)  in Mediasense Sever. Apart from CUBE based recording ,is there any other solution for it.
Best Regards,
Vector
Content for Community-Ad
